Ir para o conteúdo principal
How to Force Restart an iPhone 6s
  1. How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: passo 1, imagem 1 %32 How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: passo 1, imagem 2 %32
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 6s: passo 2, imagem 1 %32 How to Force Restart an iPhone 6s: passo 2, imagem 2 %32
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do u do then it gust goes black and won't turn on
    Angelina Walker - Responder
    Another question. What to do when these force start instructions result in a dead black, unchanged screen?
    csrmclaughlin - Responder
    So I’ve replaced the screen but still have just a blank black screen, when I try turning it on it has the plug in and charge icon pops up, and goes off when I unplug, but nothin else will display on screen!!! HELPPPP!! PLEASE!!
    Marc Andriani - Responder
Linha de Chegada
276 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
223.466 Reputação
Autoria de 168 guias
22 comentários
Thank you! Thank you! This tip saved my day!
pamathis - Responder
I dropped my phone in the garage it locked my screen when I turn it on it has lines across real colorful but locked I m not able to retrieve contacts or photos from it…is there any hope,? I had to purchase another phone same one iPhone 6s I really need my contacts and photos from this phone?
atina1951 - Responder
my home button doesnt work, how do i do this without the home button?
Kennedy Truong - Responder
its not  working for me I been trying it and just did again any other suggestions when u have no ride
Amanda Wright - Responder
Swollen battery kept the home button from properly working on my phone, it spread the case apart slightly. Do you have battery problems?
Eric Andersen -
If the home button was malfunction, how to force restart?
Tseng Stanley - Responder
Brillant guide. Was my first time opening up an iPhone for repair. Guess what? It even works afterwards, which, I have to admit, is rarely the case when I try to fix something. Thanks
Karsten Fischer - Responder
Kit fit great. Be patient when installing. Would recommend
Danny Mosley - Responder
i did this with my phone and a bunch of grey lines appeared and then it went completely black and no logo came up?
haileyfarlow123 - Responder
It is just off, it doesn’t do anything, even I left it hooked for the hole day and it won’t even show the battery when charging. Is there any way to full reset? I do not even care anymore for what I have, I just want my phone back.
ronster65 - Responder
what if the homebutton does not work? Is there a way to restart then?
Sharon Held - Responder
i got so incredibly lucky. i actually misplaced two of the screws belonging to the panel that holds down the 3 display connector cables, saying “&&^& it” and only using the two at my disposal. fearing having to buy a new phone (having completed all the steps), i forced a restart and… it works perfectly. no common issues that i had seen in any of these comments. thanks so much!!
Jack Larson - Responder
Well done guide. Thanks.
Leon - Responder
et quoi faire si mon bouton home ne marche plus ?
Sara Bjd - Responder
Amazing trick! Last thing I needed was to get a new phone right now.
jgensib - Responder
on/off bottom on right hand side does not work after battery change
is there any possibility to make a hard reset?
on my mcbook in finder it is not possible
Kai Gundrum - Responder
Se queda la manzana a reiniciarlo y de ahi no pasa😢😢
Alejandro piña - Responder
솔직히 최신형 홈버튼 없는 iPhone이 강제 재시동은 편할 것 같네요..
Turtle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 47
Últimos 7 dias: 278
Últimos 30 dias: 1,111
Duração total: 275,134
