Ir para o conteúdo principal
How to Force Restart an iPhone 4S
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: passo 1, imagem 1 %32 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: passo 1, imagem 2 %32
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 4S: passo 2, imagem 1 %32 How to Force Restart an iPhone 4S: passo 2, imagem 2 %32
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
Linha de Chegada
240 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
228.069 Reputação
Autoria de 168 guias
24Comentários do guia
what if our power butoon is broken/
Autumn Harris - Responder
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers -
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - Responder
Great Instructions! Thank you.
georgiaruocco - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 58
Últimos 30 dias: 261
Ao todo: 88,751
