Introdução
Performing a force restart should not delete any data, but it can be useful if your iPhone 11 Pro Max is frozen or needs troubleshooting.
Quickly press and release the Volume Up button (1).
Quickly press and release the Volume Down button (2).
Finally, press and hold the side button (3) until the Apple logo appears, and then release.
The screen will temporarily go dark as the iPhone shuts down and reboots. Keep holding the button until you see the logo. Save
Und wenn das iPhone auf Tastendruck nicht reagiert?
You're finished!
You're finished!
40 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
15 comentários
Klappt - vielen Dank:-)))
This Worked! Thank You so much!
❤️Many thanks
Still not working
still didnt work
same im trying a million times and nothing
still not working
It worked perfectly!
still didnt work
help me please
Thank you! I have never had an app freeze like that.
der Tipp, nur ganz kurz zu drücken, war ausschlaggebend. Vielen Dank, Iphone wieder okay!
thank you it help me
Thank you for helping me.
Worked. Thanks alot
Thank you so much! This truly worked! We didn’t know what to do with my phone when it froze this was a life saver more importantly because customer service closed earlier! Thanks again
Marco Jackson - Responder
So my question is do you do this simultaneously?? Or one at a time?
jameciahardy - Responder
this worked, but had to do it a few times, phew ! Thanks
lise bourgeois - Responder
okay i see the coment everyone says it working but i pressed them down and nothing showed up .please respond
Ernest Toth 11 Clifton - Responder
i’ve done this many times nothing happens need phone traveling in the morning
kjmil54 - Responder
