Ir para o conteúdo principal
How to Fix the Side Pocket's Elastic on a Backpack
O que você precisa
    1. How to Fix the Side Pocket's Elastic on a Backpack, How to Fix the Side Pocket's Elastic on a Backpack: passo 1, imagem 1 %32
      • Trim any excess thread and frayed edges from the fabric with your scissors.
      Pergunte ao FixBot
      Comentar
    2. How to Fix the Side Pocket's Elastic on a Backpack: passo 2, imagem 1 %32
      • Stretch the elastic to match in length with the fabric.
      Pergunte ao FixBot
      Comentar
    3. How to Fix the Side Pocket's Elastic on a Backpack: passo 3, imagem 1 %32
      • Tuck the fabric edge back into the elastic.
      Pergunte ao FixBot
      Comentar
    4. How to Fix the Side Pocket's Elastic on a Backpack: passo 4, imagem 1 %32
      • Pin the fabric and elastic together.
      • Working with needles and pins can be dangerous.
      Pergunte ao FixBot
      Comentar
    5. How to Fix the Side Pocket's Elastic on a Backpack: passo 5, imagem 1 %32
      • Begin stitching the fabric and elastic together.
      • Start about one centimeter before the tear begins.
      Pergunte ao FixBot
      Comentar
    6. How to Fix the Side Pocket's Elastic on a Backpack: passo 6, imagem 1 %32
      • Continue stitching and remove pins when you sew past the part they're holding together.
      Pergunte ao FixBot
      Comentar
    7. How to Fix the Side Pocket's Elastic on a Backpack: passo 7, imagem 1 %32
      • Stitch until you have passed the end of the tear by about a centimeter.
      Pergunte ao FixBot
      Comentar
    8. How to Fix the Side Pocket's Elastic on a Backpack: passo 8, imagem 1 %32
      • End the stitch by tying a small knot close to where the thread passes through the fabric.
      Pergunte ao FixBot
      Comentar
    9. How to Fix the Side Pocket's Elastic on a Backpack: passo 9, imagem 1 %32
      • Cut the thread just above the knot so there is little excess.
      Pergunte ao FixBot
      Comentar
    10. How to Fix the Side Pocket's Elastic on a Backpack: passo 10, imagem 1 %32
      • Clean your work space and put away the tools
      • Congratulations, you're done!
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Emily Burnside
Membro desde: 09/29/15
155 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-6, Green Fall 2015 Membro de Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 17
Últimos 30 dias: 100
Ao todo: 10,079
