Ir para o conteúdo principal
How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X
O que você precisa
  1. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 1, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 1, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 1, imagem 3 %32
    • Turn the Sorrento Grey Loveseat over.
  2. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 2, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 2, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 2, imagem 3 %32
    • Remove the snap cover that is covering the back to show the seat's sliding mechanism.
  3. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 3, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 3, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 3, imagem 3 %32
    • Pull off the seat connected to its base by pulling the clamps on both sides outward and the seat towards your body.
  4. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 4, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 4, imagem 2 %32
    • Align the hole of the sliding mechanism to hole on the wood of the seat.
  5. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 5, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 5, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 5, imagem 3 %32
    • Insert a screw into the hole and secure a bolt on the end.
  6. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 6, imagem 1 %32
    • Use a drill and vice grips to secure the bolt on the screw.
  7. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 7, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 7, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 7, imagem 3 %32
    • Attach the seat back onto the loveseat.
  8. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 8, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 8, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 8, imagem 3 %32
    • Use force to lock the seat into place.
  9. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 9, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 9, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 9, imagem 3 %32
    • Cover the sliding mechanisms with the snap cover.
  10. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 10, imagem 1 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 10, imagem 2 %32 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: passo 10, imagem 3 %32
    • Guide and place the loveseat back into upright position.
Conclusão
Shaquan Mayes
Membro desde: 09/24/21
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 326
