Ir para o conteúdo principal
How to Fix an Xbox One Controller Stuck Button
O que você precisa
  1. How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: passo 1, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: passo 1, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: passo 1, imagem 3 %32
    • Use an opening tool to remove the back panels of the controller.
  2. How to Fix an Xbox One Controller Stuck Button: passo 2, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 2, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 2, imagem 3 %32
    • Remove the five screws from the back of the controller.
    • The 5th screw is behind the sticker in the battery compartment.
  3. How to Fix an Xbox One Controller Stuck Button: passo 3, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 3, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 3, imagem 3 %32
    • Remove the front and back covers.
    • Remove the screws on the inside.
  4. How to Fix an Xbox One Controller Stuck Button: passo 4, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 4, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 4, imagem 3 %32
    • Remove the screws.
    • Flip the controller over and remove the joysticks.
  5. How to Fix an Xbox One Controller Stuck Button: passo 5, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 5, imagem 2 %32
    • Remove both screws near the trigger.
  6. How to Fix an Xbox One Controller Stuck Button: passo 6, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 6, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 6, imagem 3 %32
    • Remove the triggers to create more space.
    • Remove the screws holding the motherboard.
  7. How to Fix an Xbox One Controller Stuck Button: passo 7, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 7, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 7, imagem 3 %32
    • Remove the screws underneath the first chip board.
  8. How to Fix an Xbox One Controller Stuck Button: passo 8, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 8, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 8, imagem 3 %32
    • Remove all screws holding the motherboard.
    • Pry open the top of the controller to release the motherboard.
  9. How to Fix an Xbox One Controller Stuck Button: passo 9, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 9, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 9, imagem 3 %32
    • Remove the motherboard.
    • Remove the buttons.
  10. How to Fix an Xbox One Controller Stuck Button: passo 10, imagem 1 %32 How to Fix an Xbox One Controller Stuck Button: passo 10, imagem 2 %32 How to Fix an Xbox One Controller Stuck Button: passo 10, imagem 3 %32
    • Clean the new buttons with rubbing alcohol for less friction.
    • Clean the controller frame holes.
Conclusão
Uma outra pessoa concluiu este guia.
iAmChrisBro
Membro desde: 10/27/23
218 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 73
Últimos 30 dias: 228
Ao todo: 4,155
