Ir para o conteúdo principal
How to Fix an Overextending Holga 120N Camera Shutter
O que você precisa
  1. How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: passo 1, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: passo 1, imagem 2 %32
    • Slide the two metal lanyard locks up and off the camera.
    • Pop the back of the camera off.
  2. How to Fix an Overextending Holga 120N Camera Shutter: passo 2, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 2, imagem 2 %32
    • Remove the screw above the opening to the shutter piece using a Phillips #00 screwdriver.
    • Remove the screw below the opening to the shutter piece using a Phillips #00 screwdriver.
  3. How to Fix an Overextending Holga 120N Camera Shutter: passo 3, imagem 1 %32
    • Pull the shutter piece out and away from the camera.
    • Pull the shutter piece away carefully to avoid snapping the wire.
  4. How to Fix an Overextending Holga 120N Camera Shutter: passo 4, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 4, imagem 2 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 4, imagem 3 %32
    • Cut off the spade terminal's right prong with scissors.
  5. How to Fix an Overextending Holga 120N Camera Shutter: passo 5, imagem 1 %32
    • Bend the spade terminal forward at a 90-degree angle.
  6. How to Fix an Overextending Holga 120N Camera Shutter: passo 6, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 6, imagem 2 %32
    • Slice the blue plastic off of the spade terminal with the boxcutter/Exacto-knife.
    • The plastic bottom is sealed on very tightly. Use caution when cutting it away!
    • Remove the plastic from the spade terminal.
  7. How to Fix an Overextending Holga 120N Camera Shutter: passo 7, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 7, imagem 2 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 7, imagem 3 %32
    • Place hot glue at the bottom of the spade terminal.
    • Place the spade terminal in the small hole underneath the shutter.
    • Point the spade terminal horizontally, facing the wire that leads back to the camera.
  8. How to Fix an Overextending Holga 120N Camera Shutter: passo 8, imagem 1 %32
    • Screw the shutter piece back into place using a Phillips #00 screwdriver.
  9. How to Fix an Overextending Holga 120N Camera Shutter: passo 9, imagem 1 %32 How to Fix an Overextending Holga 120N Camera Shutter: passo 9, imagem 2 %32
    • Return the back of the camera into place.
Conclusão
You’ve now learned the following:
  • How to disassemble and reassemble a Holga 120N camera
  • How to add a spade terminal as a blocker
The spade terminal will stop the overextended shutter. Enjoy taking pictures!
Jacob DeLany
Membro desde: 09/28/21
169 Reputação
Autoria de 1 guia
Um comentário
That's a PZ1 bit which gets the screws out easily. If you got the screws out with a PH00 bit, either they changed the way the camera is made before mine was made or you are quite tenacious in your screwdriving.
s l - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 68
Duração total: 1,485
