Ir para o conteúdo principal
How to Fix an OXO Container's Jammed Button
O que você precisa
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: passo 1, imagem 1 %32 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: passo 1, imagem 2 %32 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: passo 1, imagem 3 %32
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: passo 2, imagem 1 %32 How to Fix an OXO Container's Jammed Button: passo 2, imagem 2 %32 How to Fix an OXO Container's Jammed Button: passo 2, imagem 3 %32
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: passo 3, imagem 1 %32
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: passo 4, imagem 1 %32 How to Fix an OXO Container's Jammed Button: passo 4, imagem 2 %32
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: passo 5, imagem 1 %32 How to Fix an OXO Container's Jammed Button: passo 5, imagem 2 %32
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: passo 6, imagem 1 %32 How to Fix an OXO Container's Jammed Button: passo 6, imagem 2 %32 How to Fix an OXO Container's Jammed Button: passo 6, imagem 3 %32
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
Conclusão
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
Allen Wong
Membro desde: 02/03/23
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-5, Andersen Winter 2023 Membro de UC Davis, Team 2-5, Andersen Winter 2023
UCD-ANDERSEN-W23S2G5
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 48
Últimos 30 dias: 308
Duração total: 3,410
