Ir para o conteúdo principal
How to Fix an Armhole Gape
O que você precisa
  1. How to Fix an Armhole Gape, How to Fix an Armhole Gape: passo 1, imagem 1 %32
    • Gather the supplies needed.
  2. How to Fix an Armhole Gape: passo 2, imagem 1 %32 How to Fix an Armhole Gape: passo 2, imagem 2 %32
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Fix an Armhole Gape: passo 3, imagem 1 %32 How to Fix an Armhole Gape: passo 3, imagem 2 %32 How to Fix an Armhole Gape: passo 3, imagem 3 %32
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Fix an Armhole Gape: passo 4, imagem 1 %32 How to Fix an Armhole Gape: passo 4, imagem 2 %32 How to Fix an Armhole Gape: passo 4, imagem 3 %32
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Fix an Armhole Gape: passo 5, imagem 1 %32
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Fix an Armhole Gape: passo 6, imagem 1 %32
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
Conclusão
Thank you for taking the time to read this.
Danielle Fontanos
Membro desde: 10/23/23
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 339
