Ir para o conteúdo principal
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
O que você precisa
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 1, imagem 1 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 1, imagem 2 %32
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 2, imagem 1 %32
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 3, imagem 1 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 3, imagem 2 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 3, imagem 3 %32
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 4, imagem 1 %32
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 5, imagem 1 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 5, imagem 2 %32
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 6, imagem 1 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 6, imagem 2 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 6, imagem 3 %32
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 7, imagem 1 %32
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 8, imagem 1 %32 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: passo 8, imagem 2 %32
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
Conclusão
Anoop Shahi
Membro desde: 01/17/21
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 441
