Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
First, thoroughly assess your chair for loose elements.
Sit and jiggle them to test and note exactly what moves.
Position an L-bracket as if it will brace the leg to the frame of the chair.
Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
If so, consider marking the drill bit to your desired depth.
Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
Using the drill, secure your L-brackets to the chair legs first.
For extra hold and durability, use a small amount of wood glue at the chair legs joints.
Be sure to wipe away any excess wood glue.
Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
Finally, screw the second side of the L-bracket to the base of the chair.
Um comentário
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
