Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Wobbly chairs are not only uncomfortable, but often carry a safety risk.
This guide takes you through a method of reinforcing wobbly wooden chair legs through the use of metal L-brackets. Some level of experience with a cordless drill is preferable for this fix, though some minor handling instructions are covered in the guide.
O que você precisa
First, thoroughly assess your chair for loose elements.
Sit and jiggle them to test and note exactly what moves.
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
Um comentário
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
