Ir para o conteúdo principal
How to Fix a Wobbly Chair
O que você precisa
  1. How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: passo 1, imagem 1 %32 How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: passo 1, imagem 2 %32 How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: passo 1, imagem 3 %32
    • Flip the chair upside down.
    • Put the chair on your lap or on the table.
  2. How to Fix a Wobbly Chair: passo 2, imagem 1 %32 How to Fix a Wobbly Chair: passo 2, imagem 2 %32 How to Fix a Wobbly Chair: passo 2, imagem 3 %32
    • Clean and disinfect the screws.
  3. How to Fix a Wobbly Chair: passo 3, imagem 1 %32 How to Fix a Wobbly Chair: passo 3, imagem 2 %32 How to Fix a Wobbly Chair: passo 3, imagem 3 %32
    • Use a power drill with a hex bit to remove the screws.
  4. How to Fix a Wobbly Chair: passo 4, imagem 1 %32 How to Fix a Wobbly Chair: passo 4, imagem 2 %32
    • Clean the holes with a cloth or a cotton swab dipped in disinfectant.
  5. How to Fix a Wobbly Chair: passo 5, imagem 1 %32 How to Fix a Wobbly Chair: passo 5, imagem 2 %32 How to Fix a Wobbly Chair: passo 5, imagem 3 %32
    • Reinsert the new screws and washers.
    • Tightly secure the screws.
  6. How to Fix a Wobbly Chair: passo 6, imagem 1 %32 How to Fix a Wobbly Chair: passo 6, imagem 2 %32
    • Check to see if the chair is still loose.
    • If the chair doesn't wobble, then you are finished.
Linha de Chegada
Kevin Briones
Membro desde: 04/01/21
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 61
Ao todo: 1,363
