Introdução
Hello, here is a guide on what you need in order to repair a wiggly wooden leg chair. Before starting, here are the tools you will be needing:
- 2 Hex screws and 4 washers (per leg chair)
- A power drill w/an hex screw attacher
- Wet cloths or disinfecting wipes
If you have everything, then it is time to get started:
- Grab the chair and place it upside down, preferably on a table.
- Clean the areas of the chair you are going to repair. Use wet cloths or disinfecting wipes.
- Grab your power drill and attach the hex screw attacher
- Insert the drill into the screws off the legs and start removing the old drills.
- Once the screws are removed clean the holes.
- After cleaning, put the new washers into the new hex screws
- Insert the screws into the cleaned holes
- Using the power drill, drill the screws into place
- Once the screws are tightened test the chair. If the chair does not wiggle then you are done
O que você precisa
Flip the chair upside down.
Put the chair on your lap or on the table.
Linha de Chegada
