Ir para o conteúdo principal
How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case
O que você precisa
  1. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case, How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 1, imagem 1 %32
    • Disconnect the fan from the power source.
  2. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 2, imagem 1 %32
    • Locate the locking mechanism.
  3. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 3, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 3, imagem 2 %32
    • Pull the locking mechanism back and turn the front of the fan case counter clockwise and pull it off.
  4. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 4, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 4, imagem 2 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 4, imagem 3 %32
    • While holding the fan blade in place using a piece of cloth or a paper towel, remove the spinner by turning it clockwise.
    • The blades are sharp and can cause cuts.
  5. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 5, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 5, imagem 2 %32
    • Pull the fan blade off and check for damage.
  6. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 6, imagem 1 %32
    • Remove the plastic nut on the back of the fan case by turning it counter clockwise and check for damage.
  7. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 7, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 7, imagem 2 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 7, imagem 3 %32
    • Make sure the holes on the back of the blade case are lined up with the protruding parts on the motorhead and is as far back as possible.
  8. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 8, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 8, imagem 2 %32
    • While holding the blade case in place attach the plastic nut by turning it clockwise.
  9. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 9, imagem 1 %32 How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 9, imagem 2 %32
    • Attach the fan blade back.
  10. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 10, imagem 1 %32
    • While holding the fan blade in place using a piece of cloth or a paper towel, attach the spinner by turning it counter clockwise.
  11. How to Fix a Wobbly COMFORTMATE FJYPD16H2 Fan Blade Case: passo 11, imagem 1 %32
    • Attach the front of the blade case.
Linha de Chegada
Abdul Haseeb Sajid
Membro desde: 07/04/24
193 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 308
