Ir para o conteúdo principal
How to Fix a Whirlpool WDF330PAHW Door Latch
O que você precisa
  1. How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: passo 1, imagem 1 %32 How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: passo 1, imagem 2 %32
    • Open the dishwasher door and look for the retaining screws around the side edge and top edge of the dishwasher door.
  2. How to Fix a Whirlpool WDF330PAHW Door Latch: passo 2, imagem 1 %32
    • Using a T8 Torx screwdriver remove the two screws by turning counter clockwise.
  3. How to Fix a Whirlpool WDF330PAHW Door Latch: passo 3, imagem 1 %32 How to Fix a Whirlpool WDF330PAHW Door Latch: passo 3, imagem 2 %32
    • Lift the inner panel enough that you can loosen the two securing bolts on the door latch with the wrench.
    • When loosening the two bolts, leave them in and don't remove them.
  4. How to Fix a Whirlpool WDF330PAHW Door Latch: passo 4, imagem 1 %32 How to Fix a Whirlpool WDF330PAHW Door Latch: passo 4, imagem 2 %32
    • Carefully raise the dishwasher door to align the door latch with the strike plate.
    • Watch fingers while raising dishwasher door.
  5. How to Fix a Whirlpool WDF330PAHW Door Latch: passo 5, imagem 1 %32
    • Hold the door latch with your finger tips to align the door latch.
    • Then lower the door and tighten the door latch securing bolts.
  6. How to Fix a Whirlpool WDF330PAHW Door Latch: passo 6, imagem 1 %32
    • Install the inner door panel retaining screws.
    • Proceed to tighten two screws with the T8 Torx screwdriver.
    • When tightening the two screws turn clockwise.
    • Then close the dishwasher door.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 85
Duração total: 2,545
