Ir para o conteúdo principal
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
O que você precisa
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 1, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 1, imagem 2 %32
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, imagem 3 %32
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, imagem 3 %32
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 5, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, imagem 3 %32
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, imagem 3 %32
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, imagem 3 %32
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, imagem 3 %32
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, imagem 3 %32
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 11, imagem 1 %32
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, imagem 1 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, imagem 2 %32 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, imagem 3 %32
    • Reattach the magnetic side cover.
    • The controller is fixed!
Conclusão
3 outras pessoas executaram este guia.
Laurence Chan
Membro desde: 01/26/23
268 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-3, Morris Winter 2023 Membro de UC Davis, Team 2-3, Morris Winter 2023
UCD-MORRIS-W23S2G3
2 Membros
1 Guia de autoria
3Comentários do guia
The problem is it keeps happening after doing all these steps. is there any way or parts to replace the trigger sensor completely? Possibly with a nice hall effect sensor?
John Addington - Responder
You can remove the lever bar that goes from the screw to the sensor (the one you see on Step 7)
Spray a small amount of WD40 on the sensor and use a prong to rotate the part on its full range of motion several times, that will clean up the contact inside and it completely fixed the jitter on mine.
Alex L -
hi, i made an account here just to say this worked for me but on the thrustmaster eswap S pro controller, it's almost identical aside from the cover panels
Anna Fiore - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 38
Últimos 30 dias: 121
Ao todo: 4,223
