Ir para o conteúdo principal
How to Fix a T-shirt That's Too Big
O que você precisa
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: passo 1, imagem 1 %32 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: passo 1, imagem 2 %32
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: passo 2, imagem 1 %32
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: passo 3, imagem 1 %32
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: passo 4, imagem 1 %32
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: passo 5, imagem 1 %32
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: passo 6, imagem 1 %32
    • Use scissors to cut any extra threads left over from the project.
Linha de Chegada
4 outras pessoas executaram este guia.
lakshay
Membro desde: 09/26/22
203 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 39
Duração total: 1,979
