Introdução
Before beginning this process, you will need a paper towel or cloth and tuning slide grease. This guide will teach you how to easily fix a stuck trombone tuning slide on your own without having to get a professional to do it. In order to keep your trombone in top shape, its tuning slides must be able to move easily.
O que você precisa
Carefully remove the slides from the trombone.
If the slides are completely stuck, wiggle the slides from side to side while pulling it out of the trombone.
If the slides are parallel, skip to step six. If not, attach each individual slide to the trombone and push/pull in the direction in which it would be parallel.
This will straighten the warped slides back into place.
Warped slides can be very difficult to move when attached to the trombone.
Uma outra pessoa concluiu este guia.
