Ir para o conteúdo principal
How to Fix a Stretched or Loose Canvas
O que você precisa
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: passo 1, imagem 1 %32 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: passo 1, imagem 2 %32
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: passo 2, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 2, imagem 2 %32 How to Fix a Stretched or Loose Canvas: passo 2, imagem 3 %32
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: passo 3, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 3, imagem 2 %32
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: passo 4, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 4, imagem 2 %32 How to Fix a Stretched or Loose Canvas: passo 4, imagem 3 %32
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: passo 5, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 5, imagem 2 %32
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: passo 6, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 6, imagem 2 %32 How to Fix a Stretched or Loose Canvas: passo 6, imagem 3 %32
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: passo 7, imagem 1 %32 How to Fix a Stretched or Loose Canvas: passo 7, imagem 2 %32
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
Conclusão
If it does not work, you should follow another guide where plaster is used in the canvas.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 92
Duração total: 1,397
