Ir para o conteúdo principal
How to Fix a Squeaky Door Hinge
O que você precisa
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: passo 1, imagem 1 %32
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: passo 2, imagem 1 %32
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: passo 3, imagem 1 %32
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: passo 4, imagem 1 %32
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: passo 5, imagem 1 %32
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: passo 7, imagem 1 %32
    • Use a towel to catch any drips of oil and to wipe off the hinge.
Conclusão
The door should now be quite silent when opening and closing. Thank you for reading.
3 outras pessoas executaram este guia.
Jake Herson
Membro desde: 03/30/16
219 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 128
Ao todo: 8,562
