Ir para o conteúdo principal
How to Fix a Slipping Violin Peg
O que você precisa
  1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: passo 1, imagem 1 %32 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: passo 1, imagem 2 %32 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: passo 1, imagem 3 %32
    • Completely unwind the string affected by the loose peg.
    • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
  2. How to Fix a Slipping Violin Peg: passo 2, imagem 1 %32
    • Slide the peg out towards you to remove it from the pegbox.
    • The pegbox contains the holes that the pegs go into.
  3. How to Fix a Slipping Violin Peg: passo 3, imagem 1 %32 How to Fix a Slipping Violin Peg: passo 3, imagem 2 %32
    • Locate the points on the peg that come into contact with the pegbox.
    • Rub the peg compound all the way around the peg on the points that contact the pegbox.
  4. How to Fix a Slipping Violin Peg: passo 4, imagem 1 %32 How to Fix a Slipping Violin Peg: passo 4, imagem 2 %32 How to Fix a Slipping Violin Peg: passo 4, imagem 3 %32
    • Reinsert the peg by pushing inwards.
    • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
  5. How to Fix a Slipping Violin Peg: passo 5, imagem 1 %32 How to Fix a Slipping Violin Peg: passo 5, imagem 2 %32
    • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
  6. How to Fix a Slipping Violin Peg: passo 6, imagem 1 %32 How to Fix a Slipping Violin Peg: passo 6, imagem 2 %32 How to Fix a Slipping Violin Peg: passo 6, imagem 3 %32
    • Locate the hole on the peg and insert the string through it.
    • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
    • The scroll is the woodcarving at the top of the violin.
    • After one or two turns, angle the string toward the peg head (vertical alignment).
  7. How to Fix a Slipping Violin Peg: passo 7, imagem 1 %32 How to Fix a Slipping Violin Peg: passo 7, imagem 2 %32
    • Tune the string.
    • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
Conclusão
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 184
