Ir para o conteúdo principal
How to Fix a Skewed Wheel on a Children's Kick Scooter
O que você precisa
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, imagem 3 %32
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, imagem 3 %32
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, imagem 3 %32
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, imagem 3 %32
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, imagem 3 %32
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, imagem 3 %32
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, imagem 3 %32
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, imagem 3 %32
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, imagem 1 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, imagem 2 %32 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, imagem 3 %32
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Linha de Chegada
Amir Issagali
Membro desde: 01/10/21
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 1,475
