Ir para o conteúdo principal
How to Fix a Screw-less Jammed Flexi Retractable Dog Leash
O que você precisa
  1. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash, How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 1, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash, How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 1, imagem 2 %32
    • Locate the detachable T-shaped opening at the bottom of the dog leash.
    • Insert a pry tool into the bottom of the "T".
  2. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 2, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 2, imagem 2 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 2, imagem 3 %32
    • Insert fingers into the gap made by the screwdriver and pull apart.
    • The case may take some effort to pry apart.
    • Completely separate the two halves of the case.
    • The leash lock, rope, roll, and detachable hole that allows the roll out of the case are not attached to the case and may fall out upon opening the case.
  3. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 3, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 3, imagem 2 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 3, imagem 3 %32
    • Examine the exposed components.
    • Leash Roll
    • Leash Rope
    • Leash Lock
    • Detachable hole that allows the rope out of the case
  4. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 4, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 4, imagem 2 %32
    • Lift up the leash lock to remove it from the case and place it aside.
  5. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 5, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 5, imagem 2 %32
    • Lift up the detachable hole that allows the rope out of the case. Remove it from the case and place it aside.
  6. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 6, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 6, imagem 2 %32
    • Examine the coil of the rope around the roll to spot any issues.
    • Issues may include tangles, twists, knots, or debris.
    • Unravel the rope from the roll in a counter-clockwise motion.
    • Remove any tangles, twists, knots, or debris interfering with the rope.
  7. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 7, imagem 1 %32
    • Let the rope wind back up, making sure to keep it aligned, straight, and flat against the roll.
  8. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 8, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 8, imagem 2 %32
    • Replace the detachable hole that allows the rope out of the case into its slot at the top of one of the case halves.
    • Keep the case on a flat surface after reattachment to ensure the leash opening does not fall out while replacing other components.
  9. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 9, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 9, imagem 2 %32
    • Place the leash lock back into its place behind the detachable hole that allows the rope out of the case, and on top of the spring.
  10. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 10, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 10, imagem 2 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 10, imagem 3 %32
    • Find the locking screws on both halves of the cases.
    • Align the locking screws with their corresponding holes.
    • Place the two case halves atop one another and clamp the two halves together.
  11. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 11, imagem 1 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 11, imagem 2 %32 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: passo 11, imagem 3 %32
    • Press together very tightly to finish reassembly.
Linha de Chegada
6 outras pessoas executaram este guia.
[deleted]
Membro desde: 02/20/20
247 Reputação
Autoria de 1 guia
2 comentários
Non vedo l'apertura a forma di T al di sotto del guinzaglio, è un Flexi Standard 2, come faccio ?
Atlas _ - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 51
Últimos 7 dias: 304
Últimos 30 dias: 1,363
Duração total: 32,009
