Ir para o conteúdo principal
How to Fix a Ripped Belt Loop on a Pair of Jeans
O que você precisa
  1. How to Fix a Ripped Belt Loop on a Pair of Jeans, How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 1, imagem 1 %32
    • Identify where on the pair of pants/jeans the belt loop has been torn.
  2. How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 2, imagem 1 %32 How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 2, imagem 2 %32
    • Thread one end of the thread through the eye hole at the top of the needle.
    • The thread must be through the eye of the needle as shown with extra thread past the eye or else the thread will fall out during sewing.
  3. How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 3, imagem 1 %32
    • Push the needle through from the back to the front of the pants making sure to pierce both the belt loop and the pants.
  4. How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 4, imagem 1 %32 How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 4, imagem 2 %32
    • Repeat the process in and out of the pants.
    • When you get to the right end of the belt loop continue the process back to where you began.
  5. How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 5, imagem 1 %32 How to Fix a Ripped Belt Loop on a Pair of Jeans: passo 5, imagem 2 %32
    • Tie the thread together three to four times with a basic knot and cut the excess.
    • Tug the belt loop to check if it is secure.
    • If the belt loop does not budge you have successfully followed this guide.
    • If it does not budge you will need to remove the thread and restart from Step 3.
Conclusão
[deleted]
Membro desde: 09/29/20
175 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 52
Últimos 30 dias: 256
Duração total: 14,137
