Ir para o conteúdo principal
How to Fix a Popped Rubik’s Cube
O que você precisa
  1. How to Fix a Popped Rubik’s Cube, How to Fix a Popped Rubik’s Cube: passo 1, imagem 1 %32 How to Fix a Popped Rubik’s Cube, How to Fix a Popped Rubik’s Cube: passo 1, imagem 2 %32
    • Place your cube down and look for the popped pieces.
    • Collect all the popped pieces and group the corners and the edges separately.
  2. How to Fix a Popped Rubik’s Cube: passo 2, imagem 1 %32 How to Fix a Popped Rubik’s Cube: passo 2, imagem 2 %32
    • Place the pieces layer by layer to make it easier to put the cube back together.
    • If only pieces that popped are from the second and third layer, start with the edges of the second layer.
  3. How to Fix a Popped Rubik’s Cube: passo 3, imagem 1 %32 How to Fix a Popped Rubik’s Cube: passo 3, imagem 2 %32 How to Fix a Popped Rubik’s Cube: passo 3, imagem 3 %32
    • Place the edges and corners that popped from the third layer.
  4. How to Fix a Popped Rubik’s Cube: passo 4, imagem 1 %32 How to Fix a Popped Rubik’s Cube: passo 4, imagem 2 %32 How to Fix a Popped Rubik’s Cube: passo 4, imagem 3 %32
    • Twist the third layer 45°.
    • Place the corners of the third and last layer.
  5. How to Fix a Popped Rubik’s Cube: passo 5, imagem 1 %32 How to Fix a Popped Rubik’s Cube: passo 5, imagem 2 %32 How to Fix a Popped Rubik’s Cube: passo 5, imagem 3 %32
    • Last but not least, place the final edge piece.
    • To make it easier to place, pull apart the two corner pieces slightly and insert the edge at an angle. Twist it a little bit until it goes in.
  6. How to Fix a Popped Rubik’s Cube: passo 6, imagem 1 %32 How to Fix a Popped Rubik’s Cube: passo 6, imagem 2 %32 How to Fix a Popped Rubik’s Cube: passo 6, imagem 3 %32
    • This last step is for cubes with this feature, like many speed cubes.
    • Remove the cap to expose the screw attached to the core.
    • You can remove the cap with your nails or any prying tool like a spudger or opening tool.
    • Tighten the loose screws. (It can be anywhere from 180° to 360°)
    • Make sure to tighten the screw enough so that it won't pop easily. Tightening the cube will make it pop less, but may make corner cutting worse. (Corner cutting allows turning with misaligned layers on speed cubes)
Conclusão
This simple yet effective fix will help you prevent any future pops in your Rubik's cube. I hope this guide helped you a lot!
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 80
Ao todo: 9,522
