Ir para o conteúdo principal
How to Fix a Non-Sticky Cutting Mat
O que você precisa
  1. How to Fix a Non-Sticky Cutting Mat, How to Fix a Non-Sticky Cutting Mat: passo 1, imagem 1 %32
    • Place the non-sticky mat on a flat surface.
  2. How to Fix a Non-Sticky Cutting Mat: passo 2, imagem 1 %32
    • Spray the non-sticky cutting mat with a spray cleaner covering the entire mat.
  3. How to Fix a Non-Sticky Cutting Mat: passo 3, imagem 1 %32
    • Let it sit for 5-10 minutes.
  4. How to Fix a Non-Sticky Cutting Mat: passo 4, imagem 1 %32
    • Use a scraper to gently push the dirt off the mat that is causing your cutting mat not to be sticky.
  5. How to Fix a Non-Sticky Cutting Mat: passo 5, imagem 1 %32
    • Once all the dirt is removed, let it air dry.
  6. How to Fix a Non-Sticky Cutting Mat: passo 6, imagem 1 %32
    • Once dry, make sure to cover the cutting mat with its plastic cover to avoid the dust sticking to it.
Linha de Chegada
April Pantaleon
Membro desde: 09/20/20
349 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 672
