Ir para o conteúdo principal
How to Fix a Noisy/Squeaky Bicycle Chain
O que você precisa
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, imagem 1 %32 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, imagem 2 %32 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, imagem 3 %32
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, imagem 1 %32 How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, imagem 2 %32 How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, imagem 3 %32
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: passo 3, imagem 1 %32 How to Fix a Noisy/Squeaky Bicycle Chain: passo 3, imagem 2 %32
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
Linha de Chegada
Jiaming Liu
Membro desde: 09/19/20
97 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 56
Duração total: 2,257
