Ir para o conteúdo principal
How to Fix a Misaligned Desk Drawer
O que você precisa
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, imagem 1 %32 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, imagem 2 %32
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: passo 2, imagem 1 %32 How to Fix a Misaligned Desk Drawer: passo 2, imagem 2 %32
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: passo 3, imagem 1 %32 How to Fix a Misaligned Desk Drawer: passo 3, imagem 2 %32
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: passo 4, imagem 1 %32
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: passo 5, imagem 1 %32
    • Enjoy your fully functioning drawer!
Conclusão
Dante Mazzanti
Membro desde: 02/23/15
598 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 16,612
