Introdução
A loose door threshold can make it difficult to close the door fully, cause people to trip, and make unwanted noises. It can also lead to water seepage and pest entry. To prevent these issues, it's important to fix the loose threshold as quickly and efficiently as possible.
Before starting this guide, make sure you have the required tools and materials ready by your side. It’s important to note that this guide focuses on repairing a loose wooden door threshold, not thresholds made of materials such as metal or vinyl.
This guide demonstrates how to fix a loose wooden door threshold. For best results, follow each step in order, and for safety, wear work gloves to protect your hands.
O que você precisa
Use your hands to remove the door threshold.
After a few hours, remove the heavy books or other objects covering the threshold and check its stability. If it still feels wobbly, reapply or add glue to the loose area.
