Ir para o conteúdo principal
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
O que você precisa
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 1, imagem 1 %32 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 1, imagem 2 %32
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 2, imagem 1 %32 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 2, imagem 2 %32
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 3, imagem 1 %32
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 4, imagem 1 %32 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 4, imagem 2 %32
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 5, imagem 1 %32
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 6, imagem 1 %32
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 7, imagem 1 %32 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 7, imagem 2 %32
    • Tighten the two screws using a JIS #00 screwdriver.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 42
Duração total: 1,107
