Ir para o conteúdo principal
How to Fix a Loose Louver in Wooden Sliding Shutters
O que você precisa
  1. How to Fix a Loose Louver in Wooden Sliding Shutters, How to Fix a Loose Louver in Wooden Sliding Shutters: passo 1, imagem 1 %32
    • Clean the louvers with the disinfectant wipes.
  2. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 2, imagem 1 %32
    • Locate the broken or loose louver.
  3. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 3, imagem 1 %32 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 3, imagem 2 %32
    • Align the louvers so they are parallel to the ground.
    • Make sure the knob is facing the tilt bar NOT away from it.
  4. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 4, imagem 1 %32
    • Tilt the louver down creating a 30 degree angle with the bar.
  5. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 5, imagem 1 %32
    • Position the knob in between the two holes.
  6. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 6, imagem 1 %32
    • Insert the pin into the two holes.
  7. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 7, imagem 1 %32 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 7, imagem 2 %32
    • Push and secure the pin.
  8. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 8, imagem 1 %32 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 8, imagem 2 %32
    • You are finished!
Linha de Chegada
Fatima Sakhri
Membro desde: 05/08/20
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 1,413
