Ir para o conteúdo principal
How to Fix a Loose Light Socket on a Lamp Model L37721
O que você precisa
  1. How to Fix a Loose Light Socket on a Lamp Model L37721, How to Fix a Loose Light Socket on a Lamp Model L37721: passo 1, imagem 1 %32
    • Unplug the lamp from the electrical socket.
    • Ensure that there is no electrical charge in the lamp by turning the lamp on and off.
  2. How to Fix a Loose Light Socket on a Lamp Model L37721: passo 2, imagem 1 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 2, imagem 2 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 2, imagem 3 %32
    • Turn the lamp shade knob in a counterclockwise direction to remove it.
    • Lift the lampshade to remove it.
  3. How to Fix a Loose Light Socket on a Lamp Model L37721: passo 3, imagem 1 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 3, imagem 2 %32
    • Turn the light bulb in a counterclockwise direction to remove it.
  4. How to Fix a Loose Light Socket on a Lamp Model L37721: passo 4, imagem 1 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 4, imagem 2 %32
    • Lift the tabs up from the base.
    • Squeeze the lamp shade posts inward to release them.
  5. How to Fix a Loose Light Socket on a Lamp Model L37721: passo 5, imagem 1 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 5, imagem 2 %32
    • Place the flat side of the screwdriver against the flat side of the nut inside of the base.
  6. How to Fix a Loose Light Socket on a Lamp Model L37721: passo 6, imagem 1 %32 How to Fix a Loose Light Socket on a Lamp Model L37721: passo 6, imagem 2 %32
    • While placing pressure against the nut, grip the light socket and turn it in a clockwise direction until it is tight against the base.
Conclusão
Robert McNabb
Membro desde: 03/26/20
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 73
Duração total: 5,602
