Ir para o conteúdo principal
How to Fix a Loose Gate Latch on a Wooden Gate
O que você precisa
  1. How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: passo 1, imagem 1 %32 How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: passo 1, imagem 2 %32
    • Remove all screws and bolts holding your gate latch down.
    • I utilized a Phillips #2 screwdriver and 1/2 in. wrench to complete this task, however your individual gate latch may require other specified sized tools.
  2. How to Fix a Loose Gate Latch on a Wooden Gate: passo 2, imagem 1 %32
    • Remove the gate latch and verify you cannot shift the gate latch to create new holes.
  3. How to Fix a Loose Gate Latch on a Wooden Gate: passo 3, imagem 1 %32
    • Sand the entire work area with 80 Grit sandpaper and an electric sander.
  4. How to Fix a Loose Gate Latch on a Wooden Gate: passo 4, imagem 1 %32 How to Fix a Loose Gate Latch on a Wooden Gate: passo 4, imagem 2 %32
    • Use an electric drill and and a 3/8 inch carbide drill bit to create the 3/8 in. pilot holes for the anchors that will be installed.
  5. How to Fix a Loose Gate Latch on a Wooden Gate: passo 5, imagem 1 %32 How to Fix a Loose Gate Latch on a Wooden Gate: passo 5, imagem 2 %32 How to Fix a Loose Gate Latch on a Wooden Gate: passo 5, imagem 3 %32
    • Using a hammer, tap in the sleeve anchors with the washer and bolt still attached, to prevent the sleeve and anchor bolt from separating.
    • Keep tapping the sleeve anchor until most of the sleeve is seated in the wood while leaving 12.7 mm of thread protruding from the wood.
    • This will allow you to be able to reinstall the gate latch.
    • Remove the bolts and washers from Sleeve Anchors once they have been inserted into the piloted holes.
  6. How to Fix a Loose Gate Latch on a Wooden Gate: passo 6, imagem 1 %32 How to Fix a Loose Gate Latch on a Wooden Gate: passo 6, imagem 2 %32 How to Fix a Loose Gate Latch on a Wooden Gate: passo 6, imagem 3 %32
    • Reposition the gate handle and the gate latch.
    • Use a a 1/2 inch wrench to fasten the salvaged hardware onto the gate latch.
    • Reattach the gate latch and handle with the new hardware from the sleeve anchors with a 1/2 inch wrench.
Conclusão
Nicholas Stockdale
Membro desde: 05/27/23
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 133
Duração total: 1,228
