Ir para o conteúdo principal
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: passo 1, imagem 1 %32
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: passo 2, imagem 1 %32
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: passo 3, imagem 1 %32 How to Fix a Loose Cookware Lid Handle: passo 3, imagem 2 %32
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: passo 4, imagem 1 %32 How to Fix a Loose Cookware Lid Handle: passo 4, imagem 2 %32
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: passo 5, imagem 1 %32 How to Fix a Loose Cookware Lid Handle: passo 5, imagem 2 %32 How to Fix a Loose Cookware Lid Handle: passo 5, imagem 3 %32
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: passo 6, imagem 1 %32 How to Fix a Loose Cookware Lid Handle: passo 6, imagem 2 %32
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: passo 7, imagem 1 %32 How to Fix a Loose Cookware Lid Handle: passo 7, imagem 2 %32 How to Fix a Loose Cookware Lid Handle: passo 7, imagem 3 %32
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
Conclusão
Dinuk Warnapura
Membro desde: 01/11/21
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 47
Ao todo: 2,932
