Ir para o conteúdo principal
How to Fix a Loose Connector in an Anivia 1080p Webcam
O que você precisa
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, imagem 3 %32
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, imagem 3 %32
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, imagem 3 %32
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, imagem 3 %32
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, imagem 3 %32
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 6, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 6, imagem 2 %32
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 7, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 7, imagem 2 %32
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, imagem 3 %32
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, imagem 1 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, imagem 2 %32 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, imagem 3 %32
    • Snap the faceplate covering back into place.
Linha de Chegada
Duncan Holloway
Membro desde: 02/24/21
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 48
Duração total: 895
