Introdução
Use this guide to fix your leaning wooden gate. Wooden gates start to lean downwards over time as the latch cannot withstand the weight of the door. Fix your leaning wooden gate by installing a Spring Loaded wheel. Installing the wheel provides a permanent fix, ensuring the door stands straight and well balanced.
O que você precisa
Begin by measuring the gap under the gate to determine the exact height needed for correction.
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
