Introdução
Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
7 outras pessoas executaram este guia.
1Comentário do guia
Oi! como faço reboca que a parede está pintada branca?
