Ir para o conteúdo principal
How to Fix a Flexi Leash
O que você precisa
Vídeo de Apresentação
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: passo 1, imagem 1 %32
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: passo 2, imagem 1 %32 How to Fix a Flexi Leash: passo 2, imagem 2 %32 How to Fix a Flexi Leash: passo 2, imagem 3 %32
    • Start by removing all the 5.0 mm screws from the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: passo 3, imagem 1 %32 How to Fix a Flexi Leash: passo 3, imagem 2 %32 How to Fix a Flexi Leash: passo 3, imagem 3 %32
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: passo 4, imagem 1 %32 How to Fix a Flexi Leash: passo 4, imagem 2 %32
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: passo 5, imagem 1 %32 How to Fix a Flexi Leash: passo 5, imagem 2 %32 How to Fix a Flexi Leash: passo 5, imagem 3 %32
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: passo 6, imagem 1 %32 How to Fix a Flexi Leash: passo 6, imagem 2 %32 How to Fix a Flexi Leash: passo 6, imagem 3 %32
    • Finish by screwing the 5 mm screws in their original position.
Linha de Chegada
Uma outra pessoa concluiu este guia.
2Comentários do guia
Where do i buy the spring?
Andrew Storeck - Responder
Where can I get a replacement for the white middle part on lash
Lisa Bright - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 100
Ao todo: 5,750
