Ir para o conteúdo principal
How to Fix a Feather Cat Toy
O que você precisa
  1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: passo 1, imagem 1 %32 How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: passo 1, imagem 2 %32
    • Slide a crimp onto the cat toy's line.
    • Thread the line through the ring of the key clasp.
    • You should have a small loop formed at the end of the line.
  2. How to Fix a Feather Cat Toy: passo 2, imagem 1 %32 How to Fix a Feather Cat Toy: passo 2, imagem 2 %32
    • Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
    • Use your crimping tool or pliers in order to secure the crimp.
  3. How to Fix a Feather Cat Toy: passo 3, imagem 1 %32
    • Apply super glue to any cracks visible on the feather capsule for maximum security.
    • Let the feather capsule piece dry entirely before proceeding to the next step.
  4. How to Fix a Feather Cat Toy: passo 4, imagem 1 %32
    • Use regular glue to fill the inner portion of the feather capsule.
    • Fill it up only halfway in order to leave enough space for feathers.
  5. How to Fix a Feather Cat Toy: passo 5, imagem 1 %32 How to Fix a Feather Cat Toy: passo 5, imagem 2 %32
    • Individually insert the quill of each feather into the capsule.
    • Work quickly so that the glue doesn’t dry and cause the feathers to stick in the wrong direction.
  6. How to Fix a Feather Cat Toy: passo 6, imagem 1 %32
    • Press down on the clasp lever to open up the hinge.
    • Slide the loop on the feather connector into the clasp to reconnect the toy.
Conclusão
Repeat the instructions in this guide every time your cat breaks their toy!
Uma outra pessoa concluiu este guia.
Isabella Markell
Membro desde: 04/24/24
148 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-6, Whithaus Spring 2024 Membro de UC Davis, Team 1-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G6
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 59
