Ir para o conteúdo principal
How to Fix a Faulty Button on a Mayflash F300
O que você precisa
  1. How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: passo 1, imagem 1 %32 How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: passo 1, imagem 2 %32
    • Flip around the Mayflash F300, so that the metal panel is facing you.
    • It may be helpful to place the device on a box if you cannot hold it, as the joystick would otherwise be under pressure.
  2. How to Fix a Faulty Button on a Mayflash F300: passo 2, imagem 1 %32 How to Fix a Faulty Button on a Mayflash F300: passo 2, imagem 2 %32 How to Fix a Faulty Button on a Mayflash F300: passo 2, imagem 3 %32
    • Unscrew the six 9 mm Phillips #00 screws that hold together the metal panel.
    • Gently pry the panel away once it is unscrewed.
  3. How to Fix a Faulty Button on a Mayflash F300: passo 3, imagem 1 %32 How to Fix a Faulty Button on a Mayflash F300: passo 3, imagem 2 %32
    • Unplug the two cables going into the button you wish to clean or replace.
    • These two cables can be quite stubborn to remove, so gently wiggling them as you pull will make it easier.
  4. How to Fix a Faulty Button on a Mayflash F300: passo 4, imagem 1 %32
    • Squeeze the two tabs that are on either side of the button and push it out.
  5. How to Fix a Faulty Button on a Mayflash F300: passo 5, imagem 1 %32
    • Grab your toothbrush and clean out all the dirt you may find inside and around the button.
    • Alternatively, if you wish to install an entirely new button, you can simply set aside the old one.
  6. How to Fix a Faulty Button on a Mayflash F300: passo 6, imagem 1 %32 How to Fix a Faulty Button on a Mayflash F300: passo 6, imagem 2 %32
    • With your button now clean and ready to go, place it in the empty slot and push it back down. Make sure it snaps in place.
  7. How to Fix a Faulty Button on a Mayflash F300: passo 7, imagem 1 %32
    • Reconnect the two cables to the button.
  8. How to Fix a Faulty Button on a Mayflash F300: passo 8, imagem 1 %32
    • Take the back panel of the arcade stick and screw it back in place.
Conclusão
Hopefully these steps were clear and useful to you! Happy gaming!
Ali Fareed
Membro desde: 01/09/24
157 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 651
