Ir para o conteúdo principal
How to Fix a Dirty Censor in a Corsair Harpoon RGB
O que você precisa
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 1, imagem 1 %32 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 1, imagem 2 %32
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 2, imagem 1 %32 How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 2, imagem 2 %32 How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 3, imagem 1 %32
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 4, imagem 1 %32 How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 4, imagem 2 %32
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 5, imagem 1 %32 How to Fix a Dirty Censor in a Corsair Harpoon RGB: passo 5, imagem 2 %32
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Conclusão
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 outras pessoas executaram este guia.
2 comentários
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Responder
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 127
Duração total: 6,252
