Ir para o conteúdo principal
How to Fix a Dent in a Hardside Suitcase
O que você precisa
  1. How to Fix a Dent in a Hardside Suitcase, How to Fix a Dent in a Hardside Suitcase: passo 1, imagem 1 %32
    • Before you begin, determine which tool is best to use for tapping out the dent, as this depends on the size of the dent. For this guide, the handle of a screwdriver was used, but a soft mallet would work well too.
    Pergunte ao FixBot
    Comentar
  2. How to Fix a Dent in a Hardside Suitcase: passo 2, imagem 1 %32
    • Use the hair dryer on the dented area for a duration of 3 minutes.
    • Move the hair dryer around the dented area to avoid heat damage to your suitcase. Wear heat-resistant gloves and check the area periodically to ensure it is not overheating.
    Pergunte ao FixBot
    Comentar
  3. How to Fix a Dent in a Hardside Suitcase: passo 3, imagem 1 %32 How to Fix a Dent in a Hardside Suitcase: passo 3, imagem 2 %32
    • Open the suitcase and use a screwdriver handle or soft mallet to tap out the dent about 3-5 times.
    • The screwdriver is being used to shape the dent back to its original shape towards the outside of the luggage.
    Pergunte ao FixBot
    Comentar
  4. How to Fix a Dent in a Hardside Suitcase: passo 4, imagem 1 %32
    • Use a hair dryer to apply heat to the dented area for 1-3 minutes, moving the heat over the area in a circular motion.
    • This will soften the suitcase material so it's easier to tap out the dent.
    Pergunte ao FixBot
    Comentar
  5. How to Fix a Dent in a Hardside Suitcase: passo 5, imagem 1 %32
    • Use a screwdriver handle or soft mallet to tap the dent back to the original shape or as close to it as possible. Hit the dent using your tool about 4-6 times.
    Pergunte ao FixBot
    Comentar
  6. How to Fix a Dent in a Hardside Suitcase: passo 6, imagem 1 %32
    • The process is complete and the suitcase is back to its normal shape and can be used!
    Pergunte ao FixBot
    Comentar
Conclusão
Samirah
Membro desde: 02/02/24
138 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 121
Ao todo: 3,234
