Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unscrew the head of the shower from the pipe with a pipe wrench.
Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
Twist the shower head back onto the pipe and tighten it with the pipe wrench.
Uma outra pessoa concluiu este guia.
