Ir para o conteúdo principal
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
O que você precisa
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, imagem 1 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, imagem 2 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, imagem 3 %32
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, imagem 1 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, imagem 2 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, imagem 3 %32
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 3, imagem 1 %32
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, imagem 1 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, imagem 2 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, imagem 3 %32
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 5, imagem 1 %32
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, imagem 1 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, imagem 2 %32 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, imagem 3 %32
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 7, imagem 1 %32
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 8, imagem 1 %32
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
Conclusão
Sydney Schuett
Membro desde: 07/20/20
211 Reputação
Autoria de 1 guia
Equipe
Um comentário
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 39
Duração total: 3,032
