Ir para o conteúdo principal
How to Fix a Corroded Outdoor Water Spigot
O que você precisa
  1. How to Fix a Corroded Outdoor Water Spigot, How to Fix a Corroded Outdoor Water Spigot: passo 1, imagem 1 %32
    • Rinse the outside ring of the spigot off with water.
  2. How to Fix a Corroded Outdoor Water Spigot: passo 2, imagem 1 %32
    • Once wet, apply 1 tbsp. of Bar Keepers Friend soft cleanser to the area(s) that has any built up residue.
  3. How to Fix a Corroded Outdoor Water Spigot: passo 3, imagem 1 %32
    • Let the solution sit for 5-10 minutes.
  4. How to Fix a Corroded Outdoor Water Spigot: passo 4, imagem 1 %32
    • Brush the cleanser that is on the spigot with a wire metal brush until you notice that the residue is gone.
  5. How to Fix a Corroded Outdoor Water Spigot: passo 5, imagem 1 %32
    • Rinse the spigot off completely with water.
  6. How to Fix a Corroded Outdoor Water Spigot: passo 6, imagem 1 %32
    • Using plumbers tape, wrap around the spigot once ensuring that is it fully covered.
  7. How to Fix a Corroded Outdoor Water Spigot: passo 7, imagem 1 %32
    • Apply the connection for your garden hose securely to the spigot.
  8. How to Fix a Corroded Outdoor Water Spigot: passo 8, imagem 1 %32
    • Turn on water to ensure there are no leaks/water sprays.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 33
Últimos 30 dias: 115
Duração total: 9,246
