Ir para o conteúdo principal
How to Fix a Carpet Dent
O que você precisa
  1. How to Fix a Carpet Dent, How to Fix a Carpet Dent: passo 1, imagem 1 %32
    • First decide what carpet dent you would like to fix.
  2. How to Fix a Carpet Dent: passo 2, imagem 1 %32
    • Rake the carpet with the fork to break up the fibers in the carpet.
  3. How to Fix a Carpet Dent: passo 3, imagem 1 %32
    • Submerge your white towel into the bowl of cold water.
  4. How to Fix a Carpet Dent: passo 4, imagem 1 %32
    • Place the damp towel over the carpet dent and push down.
  5. How to Fix a Carpet Dent: passo 5, imagem 1 %32
    • Put a steamer or clothes iron on top of the white towel so the heat from the steam can lift the carpet fibers.
  6. How to Fix a Carpet Dent: passo 6, imagem 1 %32
    • Lift up your towel and see your brand new carpet!
    • The carpet may take an hour or two to fully dry, so be careful not to step on the wet area right away!
Conclusão
In conclusion, this is an incredibly easy process which takes very little time and effort. Very helpful if you have just rearranged a room and do not want noticeable carpet dents.
Abigail Gaines
Membro desde: 02/17/21
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 627
