Ir para o conteúdo principal
How to Fix a Cabinet Door Hinge with a Damaged Base
O que você precisa
  1. How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: passo 1, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: passo 1, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: passo 1, imagem 3 %32
    • Choose the correct screwdriver to remove the damaged hinge.
    • A properly sized bit should “fill up” the screw head, utilizing both the full depth and width of the socket.
    • In general, use the largest bit size that fits snugly into the screw.
  2. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 2, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 2, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 2, imagem 3 %32
    • If the door is still attach to the cabinet, use your screwdriver to remove the screws from the door hinges.
    • Take the doors off the cabinets before you begin the repair.
  3. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 3, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 3, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 3, imagem 3 %32
    • Remove all of the screws from the first hinge of the cabinet.
  4. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 4, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 4, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 4, imagem 3 %32
    • Remove all the the screws from the second hinge of the cabinet.
  5. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 5, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 5, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 5, imagem 3 %32
    • Remove all of the screws from the door hinge.
  6. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 6, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 6, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 6, imagem 3 %32
    • Squeeze the wood filler in the damaged base of the cabinet.
    • Some wood fillers require you to mix them with hardener. For those types, add 1/3 amount of hardener with filler and mix them until a consistent texture. Then apply the mixture to the damaged area. For more clarity, watch this video.
    • Place a card beside the hole and fill the hole with wood filler.
    • Overfill the damaged base slightly, to ensure the hole is filled completely.
  7. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 7, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 7, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 7, imagem 3 %32
    • Scrape the extra filler from the base with a putty knife or stiff card to smooth the surface before it dries.
    • Leave the filler for 20 to 30 minutes to dry.
  8. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 8, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 8, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 8, imagem 3 %32
    • Place the cabinet hinge repair plate on the new base and secure with the screws that are included in the kit.
    • Make sure the plate is properly aligned with existing holes.
  9. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 9, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 9, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 9, imagem 3 %32
    • Place the new cabinet hinge on the repair plate and screw it in with a drill.
    • Note that the size of hinges and screws may vary according to the individual's need.
  10. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 10, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 10, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 10, imagem 3 %32
    • If the base was only pulled out on one side, then simply screw the new hinge on the other side.
    • If the base was pulled out, use the wood filler technique and repair plate on both sides.
  11. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 11, imagem 1 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 11, imagem 2 %32 How to Fix a Cabinet Door Hinge with a Damaged Base: passo 11, imagem 3 %32
    • Using your screwdriver, attach the door to the cabinet.
    • Make sure the door is level and aligned with the other door.
  12. How to Fix a Cabinet Door Hinge with a Damaged Base: passo 12, imagem 1 %32
    • Test the door multiple times by opening and closing it.
    • Congratulations, the door is now fixed!
Linha de Chegada
Tayyaba Riasat
Membro desde: 07/06/22
235 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 63
Últimos 7 dias: 299
Últimos 30 dias: 1,438
Duração total: 15,953
