Ir para o conteúdo principal
How to Fix a Button on an Umbrella
O que você precisa
  1. How to Fix a Button on an Umbrella, How to Fix a Button on an Umbrella: passo 1, imagem 1 %32
    • Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
  2. How to Fix a Button on an Umbrella: passo 2, imagem 1 %32 How to Fix a Button on an Umbrella: passo 2, imagem 2 %32
    • Remove the umbrella handle by pushing on the eject push-up button.
  3. How to Fix a Button on an Umbrella: passo 3, imagem 1 %32 How to Fix a Button on an Umbrella: passo 3, imagem 2 %32
    • Place a thin malleable metal in between the button’s connection to the metal projection.
  4. How to Fix a Button on an Umbrella: passo 4, imagem 1 %32 How to Fix a Button on an Umbrella: passo 4, imagem 2 %32
    • Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
  5. How to Fix a Button on an Umbrella: passo 5, imagem 1 %32
    • Verify that the button is firmly fixated to the metal ejector.
  6. How to Fix a Button on an Umbrella: passo 6, imagem 1 %32 How to Fix a Button on an Umbrella: passo 6, imagem 2 %32
    • Proceed to push down on the button while placing the handle.
    • The button goes through the handles button crevice.
  7. How to Fix a Button on an Umbrella: passo 7, imagem 1 %32
    • Verify that the button is firmly fixated on the metal ejector.
  8. How to Fix a Button on an Umbrella: passo 8, imagem 1 %32
    • Pound a nail with a hammer to prevent the opening system from turning.
  9. How to Fix a Button on an Umbrella: passo 9, imagem 1 %32
    • Return the screw to fixate the handle to the umbrella.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 137
Últimos 30 dias: 685
Duração total: 11,737
