Ir para o conteúdo principal
How to Fix a Brother DCP-7060N Paper Jam
  1. How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: passo 1, imagem 1 %32 How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: passo 1, imagem 2 %32
    • Press the power button on the side of the printer to turn it off.
  2. How to Fix a Brother DCP-7060N Paper Jam: passo 2, imagem 1 %32
    • Wait for ten minutes or until the printer has cooled down completely.
    • Touch the top cover to make sure the temperature has cooled down.
  3. How to Fix a Brother DCP-7060N Paper Jam: passo 3, imagem 1 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 3, imagem 2 %32
    • Open the front tray carefully.
    • Check the status of the three rollers. If there is a paper jam, pull the paper out carefully.
  4. How to Fix a Brother DCP-7060N Paper Jam: passo 4, imagem 1 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 4, imagem 2 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 4, imagem 3 %32
    • Pull two sides at the position in the photo to open the front cover.
    • Remove the drum from two sides in the position in the photo.
    • Draw out the toner at the photo position.
  5. How to Fix a Brother DCP-7060N Paper Jam: passo 5, imagem 1 %32
    • Check inside if there is paper jam.
    • If there is a paper jam, carefully remove the paper with two hands and ensure there is nothing else inside.
  6. How to Fix a Brother DCP-7060N Paper Jam: passo 6, imagem 1 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 6, imagem 2 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 6, imagem 3 %32
    • Turn the printer around.
    • Open the back cover of the printer at the position in photo.
    • Remove the back cover and check the status inside.
    • If there is a paper jam, take out the paper along the exit direction carefully.
  7. How to Fix a Brother DCP-7060N Paper Jam: passo 7, imagem 1 %32 How to Fix a Brother DCP-7060N Paper Jam: passo 7, imagem 2 %32
    • Close all covers and consumables bin.
Conclusão
3 outras pessoas executaram este guia.
KehaoWu
Membro desde: 01/15/22
224 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 96
Duração total: 1,790
